rounded corners
Saso Goricar
rounded corners
on Apr 3, 2020 at 5:54:33 pm
Hey, is there a way or expression to make radius corners only on two corners, not on all four in a rectangle shape? Thanks for your help.
Jim Scott
Re: rounded corners
on Apr 4, 2020 at 12:25:08 am
You could duplicate the Rectangle Path on the shape layer, select the shape layer and then click on Add and select "Merge Paths." A Merge Paths 1 and Stroke 1 will be created. You can then offset the rectangles vertically by using the position controls of Rectangle Path 1 and/or 2, add roundness to one or the other to get rounded corners at the top or bottom, and use the Stroke 1 that was created to control the stroke parameters.
14069_roundedrectangle.png.zip
Edit: COW's upload function seems to be having issues, so the image is not coming through.
Saso Goricar
Re: rounded corners
on Apr 4, 2020 at 12:58:31 pm
Thanks for this idea. I will try that.
