After Effects keeps freezing when I use the timewarp effect.
ryan elder
on Apr 1, 2020 at 5:48:21 pm
Everytime I try to apply the timewarp plug in, and then add motion blur to an effect, which is what I want, I will then hit the play button so it can go through the frames and add it. But every time I do this, the program always freezes after a few frames. It never seems to unfreeze so I have to shut down and try again, but it keeps on freezing whenever I attempt the timewarp.
Does anyone know what the problem could be? Thanks for any help. I really appreciate it :).
Richard Garabedain
Re: After Effects keeps freezing when I use the timewarp effect.
on Apr 1, 2020 at 8:57:45 pm
timewarp has its onw motion blur effect are you using that? How long is your video. if its too long that could be the problem...
ryan elder
on Apr 3, 2020 at 5:50:06 am
The clip I want to add it to is six seconds. However, I seem to have found a solution. If I pre-compose the clip, then it seems to work. Does precomposing do anything to it that allows it work?
I am using the motion blur effect in timewarp, yes.
ryan elder
on Apr 3, 2020 at 8:36:21 am
Actually it's back at it again now, now that I have reopened it to continue. Pre-composing is no longer helping and it will freeze any time I try to add an effect and then play through the frames.
