Bug Eye effect- After Effects
Kelly Armstrong
on Mar 15, 2020 at 4:55:50 pm
Hi there,
I need to make my footage look as though its coming from an insect's POV. I haven't shot it yet but I'd like to stay away from filming through a Kaleidoscope if possible.
Does anyone know of a way to tile footage so it looks kind of like this?
Any advise would be greatly appreciated!
Kelly
Graham Quince
Re: Bug Eye effect- After Effects
on Mar 22, 2020 at 3:18:55 pm
Try adding CC Tiler to your footage, and drop the effect's scale. This will give you lots of small versions of the shot.
Then try adding Circle, feathering it quite a bit, then in Blending mode, set it to Stenicl alpha.
Then if you add CC Hex Tile, you can create a series of hexagonal views of the same shot, but the edges are blurry.
Please ignore the fact the photo is Kate Winslet, I'd just been using a meme of her and it was the first thing I had to hand
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
Kelly Armstrong
on Mar 23, 2020 at 5:38:48 pm
Hi Graham,
Thank you so much! This is exactly what I needed!
Cheers,
Kelly
