Scribble effect and Roto-Brushing on Composition
Peter Maffay
on Mar 14, 2020 at 6:15:17 pm
Hello folks,
when doing roto-brushing or "normal" brushing, AE will demand me to do that in the layer-window instead of the composition-window. I want to sync my scribbling to the music in the composition though, which is missing in the layer-window. Is there an easy way that I can use the Brush-Tool in my AE composition or some other way to solve this issue?
Thank you guys in advance :>
Peter
Graham Quince
Re: Scribble effect and Roto-Brushing on Composition
on Mar 22, 2020 at 3:22:24 pm
If you pre-comp your footage with your music, then apply the brush effect to that precomp, you should be able to hear the music in theory, but AE will probably struggle to run the rotobrush and audio in sync.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
