How can you setup your particles to get this kkind of sliding effect?
Syed Iqbal
on Mar 11, 2020 at 8:40:36 pm
I am inspired by this motion background and want to know the technique behind this particle sliding effect. I have checked various settings in Particular but as of now, I am not being able to figure it out.
Here is the clip that I like to recreate:
https://videohive.net/item/sliding-particles/25856031
One thing I could think of was to use a light on a motion path but then it would only create one streak of particles sliding on a path using a light source as its path, whereas in the example video these are probably several dozens of streaks from left to right.
Syed
Graham Quince
Re: How can you setup your particles to get this kkind of sliding effect?
on Mar 14, 2020 at 4:38:49 pm
It’s been a little while since I played with motion paths, but I don’t think it forces every particle down a single set of coordinates, I’m fairly certain each particle will follow its own motion path based on its origin point.
Have you tried a really wide emitter and one motion path?
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
