Trim multiple paths at same speed
Baard Kolstad
on Feb 28, 2020 at 1:51:01 pm
I have imported a Illustrator file with 12 different paths inside, with various complexity and length. I converted the Illustrator file to a shape layer and applied trim paths to it. Some of the strokes move very quickly, and some very slowly. Is there any way to have them move at the same speed without manually keyframing each path?
Unfortunately I can't upload an image due to confidentiality, but hopefully you understand my question.
Thanks in advance!
Greg Gesch
Re: Trim multiple paths at same speed
on Feb 28, 2020 at 11:59:59 pm
Hi Baard. I presume that you have them ending at the same point in time? As far as I know you will have to move the final keyframes so that the ending is staggered. Speed = Distance.
