fill color setValue
Valentin Badoi
fill color setValue
on Feb 21, 2020 at 11:28:24 am
Hello,
I have the code below and i need to take the color form colorpicker and set it as fill color for my shape, but i dont figure out how to get the value from colorpicker and put it in <==fillGroup.property("Color").setValue(...........................);==>
// DIALOG
var dialog = new Window("dialog");
dialog.text = "Add Shape";
dialog.preferredSize.width = 280;
dialog.orientation = "column";
dialog.alignChildren = ["center","top"];
dialog.spacing = 10;
dialog.margins = 16;
// PANEL1
var panel1 = dialog.add("panel", undefined, undefined, {name: "panel1"});
panel1.text = "Add Elispse";
panel1.preferredSize.width = 250;
panel1.orientation = "column";
panel1.alignChildren = ["left","top"];
panel1.spacing = 10;
panel1.margins = 10;
// GROUP3
var group3 = panel1.add("group", undefined, {name: "group3"});
group3.orientation = "row";
group3.alignChildren = ["left","center"];
group3.spacing = 10;
group3.margins = 0;
var checkbox1 = group3.add("checkbox", undefined, undefined, {name: "checkbox1"});
checkbox1.text = "Fill";
var colorbutton1 = group3.add('iconbutton', undefined, undefined, {name:'coloroption1', style: 'toolbutton'});
colorbutton1.size = [100,20];
colorbutton1.fillBrush = colorbutton1.graphics.newBrush( colorbutton1.graphics.BrushType.SOLID_COLOR, [0, 0, 0, 1] );
colorbutton1.textPen = colorbutton1.graphics.newPen (colorbutton1.graphics.PenType.SOLID_COLOR,[1,1,1], 1);
colorbutton1.onDraw = customDraw;
// GROUP4
var group4 = dialog.add("group", undefined, {name: "group4"});
group4.orientation = "row";
group4.alignChildren = ["left","center"];
group4.spacing = 10;
group4.margins = 0;
var button1 = group4.add("button", undefined, undefined, {name: "button1"});
button1.text = "Add";
var button2 = group4.add("button", undefined, undefined, {name: "button2"});
button2.text = "Cancel";
//FUNCTIONS
//ADD ELIPSE BUTTON
button1.onClick = function() {
app.beginUndoGroup("Process");
addElipse();
app.endUndoGroup();
//CANCEL BUTTON
button2.onClick = function(){
dialog.close();
//ADD ELIPSE FUNCTION
function addElipse() {
var project = app.project;
var comp = project.activeItem;
if(comp == null) {
comp = project.items.addComp("CompCreated", 1920, 1080, 1, 30, 30);
comp.openInViewer();
var shapeLayer = comp.layers.addShape();
var elipseGroup = shapeLayer.property("Contents").addProperty("ADBE Vector Shape - Ellipse");
elipseGroup.property("Size").setValue([300,300]);
if(checkbox1.value == true){
var fillGroup = shapeLayer.property("Contents").addProperty("ADBE Vector Graphic - Fill");
fillGroup.property("Color").setValue(...........................); }
//COLOR PICKER
function colorpicker (result_color) {
var hexToRGB = function(hex) {
var r = hex >> 16;
var g = hex >> 8 & 0xFF;
var b = hex & 0xFF;
return [r, g, b]; };
var color_decimal = $.colorPicker();
if (color_decimal<0) return null; // added this line, to handle the case where the dialog is dismissed (else: errors)
var color_hexadecimal = color_decimal.toString(16);
var color_rgb = hexToRGB(parseInt(color_hexadecimal, 16));
var result_color = [color_rgb[0] / 255, color_rgb[1] / 255, color_rgb[2] / 255];
return result_color;
function customDraw()
{ with( this ) {
graphics.drawOSControl();
graphics.rectPath(0,0,size[0],size[1]);
graphics.fillPath(fillBrush);
if( text ) graphics.drawString(text,textPen,(size[0]-graphics.measureString (text,graphics.font,size[0])[0])/2,3,graphics.font);
function onButtonClick(){
var newcolor1 = colorpicker ();
if (newcolor1===null) return; // dialog dismissed
this.fillBrush = this.graphics.newBrush(this.graphics.BrushType.SOLID_COLOR, newcolor1);
// no need to call w.update()
// no need to reassign onDraw for the button, it's done already
// call onDraw for the button:
this.notify("onDraw");
colorbutton1.onClick = onButtonClick;
dialog.show();
Graham Quince
Re: fill color setValue
on Feb 23, 2020 at 9:28:59 am
Yikes that’s a lot of code... rather than trying to unpick it, I’ll just point out that the pickwhip can be used to identify a value on an effect and add it as code to your expression.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
