Need to generate random numbers like in an iP address
Insaf Nias
on Feb 19, 2020 at 7:12:38 am
Hi Guys,
I am literally tearing my head off ☹
I need to create an effect of a screen filled with ip addresses which keeps on changing randomly
Example - 192. 125.01.02
I have no idea on how to get the 4 punctuation.
Appreciate the help
Thank you,
Insaf Nias
Eric Santiago
Re: Need to generate random numbers like in an iP address
on Feb 19, 2020 at 4:11:59 pm
I know there is a script for that but I've had to do it using multiple comps to create that sequence.
Insaf Nias
on Feb 19, 2020 at 7:05:35 pm
Hi Eric,
But how were you able to move the position of the numbers when the it changes from 2 digits to 3, because the position of the punctuation changes as per the number of digits.
There are scripts that work like a charm, but it generates only one punctuation (ex. 192.52)
I am so damn lost ☹ been struggling for days with this thing!
Regards
Insaf Nias
Greg Gesch
on Feb 20, 2020 at 1:04:25 am
Hi Insaf. I don't know what I'm talking about but:
"There are scripts that work like a charm, but it generates only one punctuation (ex. 192.52)"
Is it possible to put two of the numbers side by side ie. 192.52, then a full stop and then add another iteration on the same line?
Insaf Nias
on Feb 20, 2020 at 6:56:39 am
Hi Greg,
The issue with that method is that the position of the punctuation changes according to the number.
I used the following script; but it give me only one punctuation point, i need 3 in total (Ex - 192.168.25.01)
frames = 10; // frames to hold each random number
seed = Math.floor((time - inPoint)/framesToTime(frames));
seedRandom(seed,true);
random(300).toFixed(2)
