Avid codecs
Antony Dupsta
Avid codecs
on Feb 12, 2020 at 3:28:11 am
I wanted to look into a possible issue that was implied but not fully tested.
Does anyone have first hand knowledge that rendering an Avid Qt from AE2017 using the Avid codec DNxHD115 will produce the same results as rendering an Avid QT from AE2019. For example, would the AVID see these identically? Would RV play these back regardless of which version rendered them?
To be super specific, the codec being used is 1080p DNxHD SQ 8-bit.
It was implied to me that the two QTs would encode differently based on 2017 or 2019 and would have playback issues in RV.
