after effect video duration
firas nadde
on Feb 4, 2020 at 12:54:20 pm
Hi Guys, Im facing a problem in changing the video duration in after effect template, Ihave followed many videos on youtube, but no success at all! every time I change the COMPOSITION SETTING INTO THE length I want, the video stays the same 22 seconds instead of 4 minutes ! please need your help.
Tero Ahlfors
Re: after effect video duration
on Feb 4, 2020 at 1:26:33 pm
The length of the work done in the comp won't change if you change the length of the composition.
firas nadde
on Feb 4, 2020 at 1:29:24 pm
any idea please !
Eric Santiago
on Feb 4, 2020 at 2:07:13 pm
What is the actual length of the video layer?
Do you see a slightly different color bar after 22 seconds on that layer?
Can it be extended?
I need more info.
firas nadde
on Feb 4, 2020 at 3:58:17 pm
Hi, Eric,
Its template, has no video, I have added video the actual length is 04:07:00 ( 4 minutes 7 seconds), there is no changes in the
color in the layers
Walter Soyka
on Feb 4, 2020 at 3:49:21 pm
A screenshot of your entire UI will help us understand what you're seeing.
Without that, here's a guess. You may need to adjust the work area before you render:
https://helpx.adobe.com/after-effects/using/previewing.html#work_area
Walter Soyka
firas nadde
on Feb 4, 2020 at 8:55:40 pm
Thank you, how to send you the screenshot please ?
