After Effects write paragraph from bottom to top?
Qendrim Spahija
on Feb 4, 2020 at 12:48:21 pm
Hi there,
I'm creating a template file in AE which I will use a lot (kind of lower thirds stuff).
What I'm trying to do is within a text box when I write something I want it to start from bottom and then go up. I'll attach some pictures of what I mean if I'm not clear.
The problem is when I have a long title (5 words or above), it has to be written in two lines, but when I have a short title, it's going to be only one line, and every time a title is short or long I have to adjust the position of the text box.
I looked over the internet but can't find a solution.
Chaz Chester
Re: After Effects write paragraph from bottom to top?
on Feb 5, 2020 at 1:34:06 pm
I don't think there's a built-in function for that. If you're using a consistent font size, I have a method that may help.
Create a slider control determines how tall your text box is:
s=thisComp.layer("Text Layer Name");
s.sourceRectAtTime().height;
Make another slider that divides that value by your font point to get the number of lines in the paragraph (in this case I used 13 for a 12.5 font point):
Math.ceil((effect("Height slider")("Slider"))/13)
Make another slider to set the initial Y value of your text box: (no expression)
Make another slider for the change in your Y value:
effect("Number of lines slider")("Slider")*13
Finally, set this expression for your text box's position:
temp = transform.position[0];
[temp, thisComp.layer("Text Layer Name").effect("Initial Y Value")("Slider")-thisComp.layer("Text Layer Name").effect("Change in Y Value")("Slider")]
This should make it so your text box moves up as you add lines, so the bottom of the text box stays in the same position.
Qendrim Spahija
on Feb 5, 2020 at 3:31:10 pm
THANK YOU SO MUCH.
