Keystroke for Timeline Window
Ben Callahan
on Jan 31, 2020 at 4:58:57 am
Anyone know a keystroke to select the Timeline window? This is killing me!
Also, on that note, is there a keystroke, once in the Effect Controls window to tab through the parameters of the effect? I'm trying to create a macro to save me some time...
Thanks for your time,
Ben
Michael Szalapski
Re: Keystroke for Timeline Window
on Jan 31, 2020 at 2:02:08 pm
You can set your own keyboard shortcuts in recent versions of After Effects, by the way.
You can toggle between the comp panel and timeline panel with the \ key.
Once you're in the effect controls panel and currently editing a property, you can tab between other keyboard-enterable effect parameters with the tab key. But, for things like color chips, you can't tab to them.
- The Great Szalam
Ben Callahan
on Jan 31, 2020 at 7:58:53 pm
Thank you for that, Michael. The \ tabs between the console and timeline but does not specifically select only the timeline.
So when I'm making a macro, there's not a specific keystroke I know will always designate the timeline only, ya know?
And maybe it's just this version, but I cannot tab through the parameters. Tab only brings up the FlowChart..
