How can I scroll down inside a script UI panel in After Effects?
David Landore
on Jan 29, 2020 at 4:21:56 am
I don't know if the title makes sense, but I installed some scripts on After Effects, and some of them are bigger than my screen resolution and I can't access some options.
I just need to find a way to scroll down and see the rest of the panel to use the scripts properly.
My screen resolution is 1366x768.
Thanks!|!
David Landore
Re: How can I scroll down inside a script UI panel in After Effects?
on Jan 29, 2020 at 9:32:07 pm
Ok, I figured it out.
If you go on "Panel Group Settings" and select "Stacked Panel Group" and then drag the inner panel down a scrollbar appears.
