Curves filter keyframing causes popping
John Ross
on Jan 21, 2020 at 8:28:06 pm
I have an element that needs subtle changes to the contrast, color etc, over time. I'm using the CURVES filter to do this. I've never had a problem like this before. The problem is, if you look close at the rendered video, you can see the item kind of popping through the different curves keyframes.
NO - they are not hold keyframes. just the normal diamond keyframe.
32bit - project is my setting, but it does the same in 16bit as well.
I'm a little baffled, not to mention disappointed.. this is pretty basic stuff.
Thanks for any suggestions.
John
Richard Garabedain
Re: Curves filter keyframing causes popping
on Jan 22, 2020 at 9:35:43 pm
I LIKE LEVELS...honestly i dont know what to say...try using the curves function under the lumetri effects and see if anything different happens
