Shortcuts not working (footage panel jump frames, send to render queue)
Claudio Sipka
on Jan 17, 2020 at 4:29:57 pm
Hi all!
I'm having real trouble to get some shortcuts to work. Since we're based in Switzerland, we are using the Swiss-German keyboard layout. I really think this has something to do with the language layout of the keyboard. AE is installed in German.
I did not yet encounter more keybinding issues than the following:
- If I open a clip into the footage view panel it should be possible to use page-up + down to jump a single frame forward or backwards.
The shortcut (alt/option + pg-up/down) to jump 10 frames at a time is wokring as it should. Even when I rebind this shortcut to anything I want, it wont work.
This error occurs on windows and mac
- The shortcut to send the comp to the render queue doesn't work on windows. Regualr ctrl + M is working but the binding with the ALT key is not working. If I hit it on the menu bar it works as it should. So it's definitly another keybinding error.
Anyone out there having similar issues with different language keyboards?
Thanks in advance!
