Add Channel Logo on a 360 video After FX
David Sellares
on Jan 13, 2020 at 5:26:57 am
Are there any way I can add still 2d images (Channel logo, text graphics) in a 360 video in After FX. A great example is a Channel Logo. I want to be able to add 2d graphics and text but not related with camera movement of a VR 360/Vr of the video. Like if it was parented to the cam in translation and rotation. I hope it makes sense.
Thanks for the help,
David
Graham Quince
Re: Add Channel Logo on a 360 video After FX
on Jan 19, 2020 at 3:11:05 pm
Nope sorry. When you create a 360 video, you’re creating a large, flat projection of a sphere. 3D video websites like YouTube then let you scan around the video, as if it was wrapped around. It’s not the same as a 3D gaming environment or even AE’s own 3D.
But, I do know YouTube have that D.o.G. Option in their channel settings that let you have a channel logo in the bottom right-hand corner. No idea if it works with 360 videos, but that would solve your problem (if you’re using YouTube)
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
David Sellares
on Jan 19, 2020 at 9:05:31 pm
Hey Graham,
Thanks for the reply. Yeah you rite about the youtube 360 videos. I found a solution to make everything work and indeed is using Unreal or Unity and exported using html5. I am hitting the wall of resolution now. Need to find a solution. I wanted to use Youtube since it is the most standard one.
David
