Adobe After Effects
Steve Galinos
Adobe After Effects
on Jan 9, 2020 at 3:04:34 pm
I am trying to proportionately stretch or close up keyframes. I select them and while holding down the ALT key drag left or right but they are all moving in one lump. Can somebody tell me what I'm doing wrong please? Steve.
Walter Soyka
Re: Adobe After Effects
on Jan 9, 2020 at 5:09:19 pm
Proportional alt-drag / stretch only works if you're dragging the first or last selected keyframe. If you grab one in the middle of the selection, they will move together as you describe.
Walter Soyka
Steve Galinos
on Jan 9, 2020 at 6:15:43 pm
Thanks you for the early response.
See the image I have attached.
Okay I had that right. When I alt-drag row by row it works but when I select all the key frames and do alt-drag it doesn't work.
So this can only be done one row at a time and not with multiple rows?
Walter Soyka
on Jan 9, 2020 at 7:39:06 pm
Nope, you should be able to do this across different layers and properties -- but you still have to manipulate either the first or last keyframe in time.
Is it possible you have keyframes selected that are offscreen?
Walter Soyka
Richard Garabedain
on Jan 9, 2020 at 10:07:16 pm
Its finicky...sometimes i feel like i have to select the keyframes alt then click...and other times i feel like i have to click then alt
Eric Santiago
on Jan 10, 2020 at 1:47:30 pm
I do believe where your play head (time indicator) matters as well.
