Masking issues
oliver abbott
Masking issues
on Jan 9, 2020 at 12:11:13 pm
Hi guys! I'm having some issues with a mask on a video layer in AE. As you can see in the image half of the image clips off at the same point each time within the comp. It does it for a few milli seconds and the rest of the clip is fine. I've messed around with the mas, turned all the effects on and off, and double checked all of the 3D positions with no luck. Any help with this would be greatly appreciated. Thanks
Cassius Marques
Re: Masking issues
on Jan 9, 2020 at 1:34:30 pm
It really seems like a 3d intersection problem or memory cache.
If you create an adjustment layer right under the car layer (to break the 3d stack order), does it solve the problem?
Cassius Marques
http://www.zapfilmes.com
oliver abbott
Re: Masking issues
on Jan 9, 2020 at 1:54:26 pm
Yeah, It really does seem like a 3d stack issue. But when I put the layer on its own the issue still arises. I have tried the adjustment layer with no success.
