Text Problem
Muslem Arqawi
Text Problem
on Dec 18, 2019 at 7:38:48 am
I can't center the text because the bounding box is just around the number.
why is it doing this and is there any way to fix it.
Graham Quince
Re: Text Problem
on Dec 21, 2019 at 11:45:32 am
Hard to tell without viewing the comp, but from your screenshot, I'd assume the 1 is it's own, separate layer. If it isn't and AE is unable to cope with arabic characters, it might be easier to manually align it.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
Muslem Arqawi
Re: Text Problem
on Dec 22, 2019 at 7:21:42 am
No, it's on the same layer
it works with the Arabic language just fine but it's when I add a number or a symbol at first it acts like this
Cye Charles
Re: Text Problem
on Dec 21, 2019 at 5:06:52 pm
You can add a shape layer to the position where you would like to center to... then parent whatever layer (inyour your case your text) to that shape whilst holding down "Shift" on your keyboard. It will snap it into place and then just unparent it and delete that unneeded shape layer. Hope that can helps you.
Muslem Arqawi
Re: Text Problem
on Dec 22, 2019 at 7:19:49 am
Thank you.
It worked amazingly
