Y Position in Graph Editor shows negative value || Repeated Explosion
Robin Zweers
on Dec 12, 2019 at 12:55:24 pm
Hey guys,
I fairly new to Adobe After Effects and I'm trying to understand the value graph. I'm encountering a difficulty and I can't seem to find an answer for it on Google, That's why I'm asking here.
So I'm trying to make a kind of explosion. A bit like
And I'm digging into the graph editor for a clearer view of the animation movement.
But what does it mean if your y position value is in the negative numbers?
Walter Soyka
Re: Y Position in Graph Editor shows negative value || Repeated Explosion
on Dec 12, 2019 at 5:39:43 pm
By default, shapes start at a position of [0,0] inside the shape layer. This point in layer space corresponds with the center of your comp ([960, 540] in comp space for an HD composition).
A negative y-value just means that the position point is above its origin in the frame.
Walter Soyka
Robin Zweers
on Dec 12, 2019 at 6:22:57 pm
Thanks! I was making myself crazy. I thought: "Well the selected triangle is above the center point in my screen, so it must have a positive y-value''. I didn't come to the idea that it is just corresponding with the center point. And that that is the reason why it's negative.
