AE shape layer size property
John Howard
on Dec 11, 2019 at 12:22:34 pm
I'm trying to create some responsive labels to export to premiere as MOGRTs.
I'm struggling to get the size property of a shape layer which I will then split x/y coordinates and add an expression to.
All I can get is a scale property but no size, sounds like it should be simple but I can't for the life of me get a size property to work with.
I've screengrabbed an image below, any help would be great!
John Howard
Re: AE shape layer size property
on Dec 11, 2019 at 5:04:12 pm
I solved the problem in the end.
Created a new shape layer, then added a rectangle to the shape layer.
You then get size property for the rectangle.
