Cinema 4D Text Stroke Extrude
Rob Bach
on Dec 10, 2019 at 11:09:18 am
The Cinema 4D renderer will not recognize the Text Stroke, if I want to extrude it as well. (Think "Toy Story" text)
Has anyone found a technique to make this happen.
Currently I need to Create Shape from Text. Then I can extrude the stroke on the shape.
I then parent the shape to the text.
This works, However, if I edit the original text.. I need to go through the whole procedure again in
setting up the Shape from text outline.
Would it be possible to apply an expression to the Shape layer to update?
A lot of work otherwise.
thanks in advance
