Is there an easy way to invert the colors of an object with effects?
Ryan Hauser
on Dec 5, 2019 at 6:54:05 pm
In my project, I only have two colors to work with -- White and Orange. I want to change the background color periodically to maintain visual interest, but to do that I need to invert the color scheme on my shape layers.
Here's what it is right now
What I'm looking for an easy way to do
I originally thought the "Change to color" effect might work, but that only affects one color. If I add a second "Change to color" effect, it is applied on top of the other effect, not simultaneously. After doing that, I just have a solid color instead of swapped colors.
I know I can precompose the composition, duplicate it, and change the colors in one of the precomps to the inverted color scheme, but that's messy and if I need to change something later it will cause many problems and take lots of time.
Cassius Marques
Re: Is there an easy way to invert the colors of an object with effects?
on Dec 5, 2019 at 7:04:28 pm
If you only have white and orange, why not make everything black and white and add an adjustment layer with a tint effect above everything?
You can just change the tint to switch colors.
Cassius Marques
http://www.zapfilmes.com
Ryan Hauser
on Dec 5, 2019 at 9:06:00 pm
Not a bad idea. Not a bad idea at all! Thanks much, I'll try that.
Eric Santiago
on Dec 5, 2019 at 9:14:39 pm
Adjustment Layer, Channel Invert?
