Animated Wind Map in After Effects
Jesse Heinilä
on Nov 29, 2019 at 7:57:42 am
Hi! I was wondering is it possible to create wind map type of animation with lines in after effects like in this example: https://media2.giphy.com/media/mbXXOu4vNhiW4/giphy.gif?cid=790b761124313adf...
or this: http://hint.fm/wind/
I tried searching for a way to make this type of animation in after effects but couldn't find anything related so I ask you geniuses here do you have any tips on how to achieve this effect in AE or can it be done with a plug-in. Thanks in advance!
Justin Hemsley
Re: Animated Wind Map in After Effects
on Nov 29, 2019 at 5:42:50 pm
I might start with "Vector Blur" that comes built into AE. It can use an image as a map, you could paint some hot spots for the lines to curve around?
