Editing Path Shape by Frame
William Wolfman
on Nov 19, 2019 at 5:00:23 pm
This is a wonky behavior in AE that I haven't quite figured a way around. I am trying to edit anchor points and it continues to respond with the Transform bounding box as oppose to editing/selecting/moving each point individually on the path.
http://www.williamwolfman.com
Oleg Pirogov
Re: Editing Path Shape by Frame
on Nov 19, 2019 at 7:50:04 pm
Selecting only the group that contains the path property gets you all the vertices unselected, so you can select those you want.
Selecting the path property selects all the vertices (and double-clicking one of them will get you the free-transform bounding box).
