Adding a symbol to this expression
Simon Jones
on Nov 19, 2019 at 2:53:07 pm
I'm using the following expression to generate values for counters used within a game (thanks to Dan Ebbert and Walter Soyka) :
frames = 15;
clockStart = 1;
rate = (1/thisComp.frameDuration) / frames;
clockTime = clockStart + rate*(time - inPoint);
Math.floor(clockTime);
The question I have is that I wish to add a £ or $ symbol in fornt of the generated number. Anyone know how i'd do that?
Cheers
Simon
it's all about the X and the Y
Cassius Marques
Re: Adding a symbol to this expression
on Nov 19, 2019 at 4:52:55 pm
If its a field that accepts strings you just need to add ("any string") + before the result (which is Math.floor...)
such as
frames = 15;
clockStart = 1;
("$")+Math.floor(clockTime);
Cassius Marques
http://www.zapfilmes.com
