sRGB Proxies Being Interpreted as Rec.709
Kevin Camin
on Nov 14, 2019 at 11:26:38 pm
I'm on 2019 (16.1.1), and this didn't happened to me with 2017. I'm working in an sRGB colorspace and creating sRGB proxies. What happens is that After Effects interprets the proxies as Rec.709 gamma 2.4 and it makes the proxie noticeably darker.
Does anyone have any thoughts on how to fix this or work around this?
Best regards,
Kevin Camin
Antoine Dorni
Re: sRGB Proxies Being Interpreted as Rec.709
on Nov 24, 2019 at 9:52:39 pm
Did you also check in your AE Project Settings ? There is a global color profile there
AfterCodecs and BRAW Studio plugins for Adobe CC https://autokroma.com/
Justin Hemsley
on Nov 29, 2019 at 5:58:28 pm
If you right click on the clip in the project window, choose "interpret footage" then "interpret proxy" you should hopefully be able to change the color management settings.
Hopefully this works?
