Unable to run aerender command over ssh using system.callSystem script
Mark Paterson
on Nov 13, 2019 at 10:27:41 pm
I've wrote a script that sends my current active project to aerender directly from a Script UI button. It works fine on my local machine like this…
myPanel.grp.group8.getPath.onClick = function() {
if(app.project.file !== null){
var path = app.project.file.fsName;
$.writeln(path);
var renderCommand = "/Applications/Adobe\\ After\\ Effects\\ 2020/aerender -project " + path;
system.callSystem(renderCommand);
However I would like the render to take place on a different machine which has access to the same files. The following Terminal command (from my machine) works and the image sequence gets rendered ok…
ssh server@192.168.50.4 /Applications/Adobe\\ After\\ Effects\\ 2020/aerender -project /Volumes/Work/Jobs/test.aep
The problem is, if I try to add ssh into the AE script like this, it does not work…
$.writeln(path);
var renderCommand = "ssh server@192.168.50.4 /Applications/Adobe\\ After\\ Effects\\ 2020/aerender -project " + path;
What am I doing wrong? What is the correct syntax to do this?
Mark Paterson
Re: Unable to run aerender command over ssh using system.callSystem script
on Nov 22, 2019 at 8:43:51 pm
The following command works. Turns out I needed to backslash the quotes in a couple of places…
var renderCommand = "ssh server@192.168.50.4 \"/Applications/Adobe\\ After\\ Effects\\ 2020/aerender -project \"" + path;
However, the issue now is that AE pinwheels until the aerender is complete on the other machine haha. The same happens when I remove ssh from the command and aerender locally. I guess I need to find a way to let it run in the background or just send the command then return focus to AE?
