Text "motion Blur" Occurs with Motion Blur off
Keith Peskosky
on Nov 10, 2019 at 6:51:59 pm
In the video I have stationary text and a single node camera that is moving past them. Motion blur is off. Comp is 29.97fps 1080p
As you can see the text "blurs" together making it hard to read.
This is something I have seen in a few of the projects I have worked with the camera and I was hoping there is just something fundamental I'm missing to stop this from happening.
Is this "blur" a limitation of the camera?
Any insight would be fantastic. Thanks for the help.
Graham Quince
Re: Text "motion Blur" Occurs with Motion Blur off
on Nov 23, 2019 at 2:28:43 pm
Motion Blur I think always occurs by default, as the Motion Blur option in the comp is just about the preview.
If you don't want Motion Blur on in rendering:
  • Add your comp to the Render Queue (instead of AME directly).
  • Click on the Best Settings and change the Motion Blur settings to Off for all layers.
  • Click OK.
  • Then click on the button Queue in AME
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
Max Haller
on Dec 2, 2019 at 9:59:53 pm
Im not sure that's really motion blur, it might just be that you want to increase the frame rate or space out the keyframes more.
Richard Garabedain
on Dec 4, 2019 at 7:57:57 pm
That is not motion blur..that is called juddering. Its when you are trying to move the text over too great of a distance in a short time span. if you can..make the timing longer...if not..try going to this
topic....https://forums.creativecow.net/thread/2/1138284#1138294
