Animated Bokeh ? - Using Particle World
Cody Coker
on Nov 4, 2019 at 10:48:32 pm
Hi everyone!
I am trying to achieve this animated bokeh effect from the trailer for the film The Signal
So I started to follow this tutorial :
Which has you using particle world and applying the Textured Disc Particle
The problem I am having is I cant seem to slow the animation down even with the velocity slider all the way to zero,
Secondly and most importantly, how can i adjust the direction of the animation? As you can see in the film trailer the bokeh is coming from left to right, I dont want it to live and die I want it to be on and come into frame.
What would you suggest?
Thank you.
Richard Garabedain
Re: Animated Bokeh ? - Using Particle World
on Nov 5, 2019 at 3:34:01 pm
did you set the gravity to really low as well?..but anyways this tutorial has you trying to fake it ..and it does not quite look as good does it. if you have the time to render do the same project with smaller particles and a stronger blur on the camera lens blur.
