Importing AI files as parametric shapes in AE
Dustin Novacek
on Oct 29, 2019 at 8:59:51 pm
I need to rig up some expressions to a shape layers "size" and "position" parameters and the layer transform "position" parameter as well. When I create the shapes directly in AE there are the shape parameters of size, position and rotation. Though, when I import AI files and convert them then they lose the options of the shape itself and the only option that is available to edit is the "path" parameter.
How do I import AI files as parametric shapes not a bezier shape?
Thanks for your help
