Camera does not work on Solids with Trapcode Particular, Element 3D, etc.
Benjamin Gardener
on Oct 20, 2019 at 12:13:57 am
I made this account for this sole purpose.
I edit videos for a hobby and came across this problem a couple days ago, I noticed I couldn't move a word I imported in to Element 3D with a Camera. I searched for an hour or two and couldn't find a single person with the same issue so I started poking around seeing if I accidentally turned on a setting or something, I replicated the issue on the same project file BUT with Trapcode Particular instead of Element 3D, the problem still occurred. After that I tried replicating the issue on a new project file, still happened. I went to a previous project file which I saved a bit back and tried to recreate it a last time and the issue didn't occur.
Oh and another strange thing is that it would also cause the layer I'm trying to move around with the camera to bug out, an example is in the GIF below
My guess is I must've accidentally toggled a setting or something that made it do what it did, but I can't figure out what
Here is a GIF of what is happening: https://gyazo.com/962768aa064cbfbca044da07e991c400
If it would be useful, I would be happy to upload the project file for inspection.
Cassius Marques
Re: Camera does not work on Solids with Trapcode Particular, Element 3D, etc.
on Oct 21, 2019 at 1:02:25 pm
No setting you can change creates that behavior. Try to update video drivers or reset AE's preferences. maybe reinstall if it all else fails.
Cassius Marques
http://www.zapfilmes.com
