Element 3D error - Element failed to initialize OpenGL
Dalibor Mitic
on Oct 18, 2019 at 2:31:02 pm
Hi, guys i hope someone can help, i have been busting my head for days and cant find solution.
I had to update windows from win 7 to win 10, and installed AE 2019 and now i have problem with VC Elelement V2 plugin will not work. When applied i am getting this error http://prntscr.com/pl4b6i Everything worked fine on win 7 and AE 2018
I figured out the problem is that AE using my integrated graphic card as OpenGL render instead of my Nvidia GTX 1070 http://prntscr.com/pl4gx6 and found workaround by disabling Intel HD graphic from device manager, when i do that AE is using my Nvidia card for opengl and Element is working fine. I would disable it completely but my 2 other monitors are connected to integrated GPU so i need it.
I have also tried to force it in nvidia control panel http://prntscr.com/pl4juz but that does not help ether.
Is there a way to force AE to use my Nvidia card for OpenGL instead Integrated Intel card? Any way, like modifying some files or some script, etc.
Thank you.
