How to match color to a color that is dynamically changing in After Effects?
patrick beck
on Oct 17, 2019 at 11:12:50 pm
Hello,
I have a fire effect (saber from VC). I am trying to tint the surrounding area to match the color of the burn/flicker effect? Is there a way to select a point on the screen to continuously match/change the color of my tinted surrounding area?
Blaise Douros
Re: How to match color to a color that is dynamically changing in After Effects?
on Oct 18, 2019 at 7:45:45 pm
Parent the color of whatever effect you're using to tint the area to the color of the blade in Saber. That will make sure the color always matches, even if you're changing the color of the blade.
patrick beck
on Oct 18, 2019 at 9:00:07 pm
Unfortunately that doesn’t work. The saber color in the settings is just one color. It must have have certain algorithms that drive the color changes. I tried that initially. Thanks though.
Greg Gesch
on Oct 18, 2019 at 11:08:11 pm
Hi Patrick, this post at the Adobe forum might give you some ideas:
https://community.adobe.com/t5/After-Effects/How-to-match-color-to-a-color-...
