emitter to follow orbital null child
Will Brenner
on Oct 17, 2019 at 2:35:18 am
I have a null in the center of a comp. I have the null rotating in 3d space. Then I parented another null (3d layer) to the rotating layer, so that it orbits the other null.
I want to use the position of the orbiting null to drive the emitter position of an CC particle world.
Is this possible and how would I do it?
Thank you!
John Williams
Re: emitter to follow orbital null child
on Oct 17, 2019 at 10:06:44 am
CC Particle Systems is a simulated 3D effect, which means it doesn't actually use true 3D Z space.
CC Particle World gives you Z space co-ordinates so you will need to use that one.
Here's a link that'll explain the expression method more clearly than I can right now.
John Williams
Soho Editors
