Hello! I hadn't run into this issue before but in the last month or so it seems to keep cropping up and I'm not sure where it's coming from as I haven't changed anything about my installation. For some reason when I export my comp the last five frames are getting cut off when I play the exported file. Which is particularly a pain when I set these up to be animations that would loop and this export issue makes the loop not perfectly restart. Let me give you an example here:
Here in this gif where I play the RAM preview you'll see that after the 'Sign up button' there is a panel of geometric shapes that slides up. This is what is happening at the end of the comp as it gets to 15 seconds to reset it back to the beginning.
https://gyazo.com/7a3c55bbc4f60e72bbe4e5f7b633a223
However when I exported this through AME the last five frames of movement of that geometric panel coming up get cut off so it just stops partway up the screen and then jumps to its starting position as the playback restarts.
https://gyazo.com/55962617063d89a4e2dfe66404a4f3bb
I've checked and rechecked that the work area is all in the proper place, it is. The export settings don't seem to indicate any reason why it would be cutting off. I keep having to add some extra frames I don't want to have there at the end so when it cuts off on export its cutting off filler. Have you ever seen this happen before or know what could be causing this strange export problem?
