Bubbling Video cauldron effect
Anna Hahn
on Sep 29, 2019 at 11:37:46 am
Hello!
I would like to make an effect in after effects that automatically spawns clouds or bubbles containing time offset reflections of the video playing in the background such that the clouds or bubbles float toward the viewer
For example if someone is speaking in a video clip, clouds or bubbles containing time offset versions of the same clip would float up toward the camera expanding indicating in perspective that they are getting closer, but you would see an overlapping random jumble of the moments that just past, like moving images of moments just past rising toward you in steam clouds
What are some good ways to go about achieving this? Are there any particle systems that make something like this easy such as any of the red giant trapcode stuff?
Graham Quince
Re: Bubbling Video cauldron effect
on Oct 6, 2019 at 4:40:35 pm
If you have the money then Trapcode Particular or Wondertouch’s Particle Illusion can do this. However, you should be able to get similar results for free using CC Particle World.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
Anna Hahn
on Oct 14, 2019 at 12:30:16 pm
Thank you so much! Do you know how to accomplish this in particular? I see how to make a polygon that is textured from a video but ideally I am looking for something more fluid the way that the built in Foam effect functions where it reflects the layer in the particles.
Michael Szalapski
on Oct 8, 2019 at 12:14:49 pm
Another built-in effect that might come in handy is Foam. It can create bubbles that reflect the layer they're placed on.
If you want each individual bubble to have a different part of the clip though, it's not going to work. You'll need Particular from Red Giant for that.
- The Great Szalam
