Wand trail effect
Matthew Boehm
Wand trail effect
on Sep 24, 2019 at 1:41:47 pm
I am trying to make a trail effect for someone who is drawing In air(similar to the disney ID). I am fairly new to after effects so I watched a tutorial online. This is the only video I could find for what I want (https://youtu.be/UKqb4pDUTsQ). I tried what he did but I can only get a dot on the and of the wand I can’t get it to make a line. Does anyone know what I am doing wrong? Or is there a better/different way to do it?
Blaise Douros
Re: Wand trail effect
on Sep 24, 2019 at 4:17:07 pm
(Sigh) watching tutorials from 14-year-olds is always going to be a recipe for frustration.
I would bet that you've made the typical rookie mistake of not knowing what to attach your track point to. I imagine you've applied the tracking data to the Transform properties of the solid layer that your particle effect is on; what you need to do is attach the tracking data to the position of the particle emitter, and NOT the layer transformation properties.
Richard Garabedain
on Sep 24, 2019 at 8:11:41 pm
lol...after he said a 14 year old made the video I had to watch...he basically just gave his version of andrew kramers tutorial..the official one..found here...https://www.videocopilot.net/tutorials/3d_stroke_effect/
Also mocha could track that wand making this a bit easier of a poject
