How can i make shadows more blue?
Richard Garabedain
on Sep 19, 2019 at 4:45:29 pm
an object casts a shadow against a ground plane...how can i color the shadow more blue to match the background...i honestly cant figure out how to
Greg Gesch
Re: How can i make shadows more blue?
on Sep 19, 2019 at 11:10:42 pm
Hi Richard. If you use either the Drop Shadow or Radial Shadow effects you can choose the shadow colour. Is that of any use? If you are using a light to cast it my instinct would be to try to make a track matte out of the shadow somehow - don't know if that is helpful but it might give you a direction to think in?
Greg Gesch
on Sep 20, 2019 at 12:53:41 am
Hi again, interesting conundrum. If you are using a light to cast the shadow:
Duplicate your object and make it into a solid black/blue silhouette (don't know what your object is so can't assist there).Put it below your object layer - parent to original if necessary. In it's material options set Casts Shadows ON, Light Transmission 100% - it will now cast a blue/black shadow.
On your object layer set it's Casts Shadows to OFF.
Now play with the colour of your silhouette till you get a colour match.
Should do it!?
