"Pull to center" radial blur?
David Gruwier
on Sep 12, 2019 at 12:33:57 pm
I remember seeing a post asking about the same thing a long while ago, but that was several years ago, and I'm hoping there might be news on this front.
Does anyone know of a "pull towards center" version of radial blur, or a simple technique to achieving the same thing?
Essentially the opposite of this: https://i.stack.imgur.com/A7yi8.jpg
I trying to create a Star Wars style hologram beam: https://vignette.wikia.nocookie.net/starwars/images/a/a5/Invisible_Hand_hol...
The way I've done it now is with an expression that duplicates the layer like 100 times, scaling them down and spacing them out evenly between the original position and a null position. It's really messy and slow, not a good solution.
Any ideas?
Blaise Douros
Re: "Pull to center" radial blur?
on Sep 12, 2019 at 4:17:06 pm
CC Light Rays does exactly this. You'll just need to play with it a bit to get the rays going the right direction. If you set the shape to Square, you can choose the direction of the light.
This might also be helpful: https://forums.creativecow.net/docs/forums/post.php?forumid=2&postid=891127
