Keying Problem on intersecting edges
Tyler McNeill
on Sep 2, 2019 at 3:51:30 pm
Hey there,
I have encoutered this problem dozends of times but I don't really know if there is a name for this. The key itself looks ok, but where 2 people are intersecting you get this bright edge that travels along the intersections. (see image)
13674_edgesschlrp.gif.zip
Is there a clever way to get rid of this? The chokers just take away the edge even where it has to stay and if I start masking the effect it is veeery timeconsuming.
Any ideas?
Thanks very much in advance!
Rich Rubasch
Re: Keying Problem on intersecting edges
on Sep 2, 2019 at 3:57:38 pm
Not sure which keyer you are using but sometimes Edge Color Correction can help here.
Also I sometimes pre process my green footage in a sub comp. I use Hue Saturation to boost only the green channel saturation and also sometimes add a denoiser. Then in the main comp I pick that now much more saturated green....this helps define the edges better.
I almost always use Edge Color Correction in Keylight and I can make any slightly green or brighter edge areas match the shirt they are wearing or a background color etc to make a more convincing composite.
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
http://www.tiltmedia.com
Tyler McNeill
on Sep 25, 2019 at 10:01:38 am
Hello Rich,
sorry, but I totally forgot to thank you for your reply. I ended up using a mixture of your method and a bunch of edge correction tools and it worked way better than before.
Thank you very much!
