Trying to do a quick edit with the Smart Import script with var targetFolder = Folder.selectDialog("Import items from folder...");
Keenan Parry
on Aug 28, 2019 at 9:49:00 pm
Hey all! So I'm fairly new to scripting and I thought this was gonna be a bit easier. I know it's easy, I just don't know the proper formatting I guess?
That's the variable that prompts the folder dialog box to open when the script is run. I want that replaced with a specified folder path so that when the script is run, it always goes to the same folder, rather than prompting the selection.
I was looking here but truly not sure if I'm on the right path: https://estk.aenhancers.com/3%20-%20File%20System%20Access/folder-object.ht...
Any help or insight would be greatly appreciated!
-Thanks
