How to avoid juddering in the rolling text in credits
Bernhard Walzl
on Aug 14, 2019 at 8:58:05 pm
Hello!
After intensive research about this, I have still no idea how to solve this very common problem:
My credits is a composition with the dimension of 1920x10000 with all the text and logos. In another comp I let this comp scroll through.
When exporting I noticed heavy jitter and the text doesn't"t roll fluently.
The frame rates match. So this can't be the problem.
What do yous all reckon what's the best way to sort this out?
Bernhard
EDIT: SOLUTION WAS FOUND:
Jim Scott
Re: How to avoid juddering in the rolling text in credits
on Aug 15, 2019 at 1:48:06 am
It would be helpful to others if you would post the solution rather than just stating that the solution was found.
Bernhard Walzl
on Aug 15, 2019 at 6:51:03 am
So I did. The youtube video was the solution ;)
Jim Scott
on Aug 15, 2019 at 12:46:06 pm
Sorry Bernhard. For some reason the video wasn't showing in my browser. Thanks for your kindheartedness.
Blaise Douros
on Aug 15, 2019 at 4:21:21 pm
This is a really over-complicated solution. Just set two keyframes, and mess with the timing to get the roll length and speed. Then turn motion blur on.
