Create an RGB Scope (Parade) in After Effects
Mathias Kalhauge
on Aug 6, 2019 at 11:34:58 am
Hey, so I was wondering if anyone knew of a way to make an RGB visualizer in After Effects?
Somewhere along the line of a waveform that shows RGB instead of audio frequencies.
It needs to look something like this:
https://cdn.lynda.com/video/381541-119-635663819150098261_338x600_thumb.jpg
Jack Chavez
Re: Create an RGB Scope (Parade) in After Effects
on Aug 6, 2019 at 8:00:15 pm
Dunno about MAKING one, but If you're running AE 2018 or earlier (all the way back to 2004) you can call up Color Finesse and presto! you have a working scope. 2019 or later you can do something similar with Lumetri and Lumetri Scope. Maybe record them in action and time ramp?
I would think making one would require quite a bit of coding but I look forward to other answers.
Cheers.
Mathias Kalhauge
on Aug 8, 2019 at 6:39:30 am
I might have found a way...
By extracting each channel to a seperate comp, and then using PixSort; I was able to sort each pixel by their luminance values for the three different channels.
It looks like the mix of parade and a histogram - so not completely realistic.
The only problem is the speed. PixSort is extremely taxing on processing, so it takes a good few 15-20 minutes to export 10 seconds.
