Complicated Table Chart
Elia Kremennoi
on Aug 6, 2019 at 10:36:36 am
Hello all.
Got an interesting task and can't figure out how to make it work in AE.
What i can't understand is how to achieve this: When green line moves up or down it has to become red and leave the static white line
I used path, created nulls from it, assigned dots to each point and animated them.
Thanks in advance.
Graham Quince
Re: Complicated Table Chart
on Aug 8, 2019 at 9:23:57 pm
So you’ve done all the hard work. All you need to do now is use a duplicate of your green line layer as a track matte for another layer. I’d be tempted to create a pre-comp with the red and black areas and include the white line too. Then this layer will only be visible when exposed where the green line is.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
