Audio Waveform FX - Skipping on export
Martin Gardiner
on Jul 25, 2019 at 4:53:52 pm
Any tips on what to do if my audio waveform fx is skipping around on my exported video? The audio/exports are working on other computer's exports, just mine is the problem.
Exporting via Media Encoder/h.264, but it works on others. Tried clearing cache, didn't help.
Cassius Marques
Re: Audio Waveform FX - Skipping on export
on Jul 25, 2019 at 7:08:13 pm
Can you clarify what is "audio waveform fx"? is it an effect? Is it a template you're using the visualize some audio? I'm a bit lost...
And what happens if you render out to another format? Like an image sequence?
Cassius Marques
http://www.zapfilmes.com
Martin Gardiner
on Jul 25, 2019 at 9:05:50 pm
it's the effect called 'audio waveform', I'll have to try to export at different formats, what would that mean if an image seq or .mov worked, but the .mp4 doesn't work, what fix is there for that? Thanks for your reply.
Cassius Marques
on Jul 26, 2019 at 12:45:22 pm
I'm not sure, perhaps reinstalling whatever AE uses for that export module (AE itself? I guess). There's also other ways to export h264 out of AE. So you could try AfterCodecs before reinstalling if only that output is the problem.
Cassius Marques
