NEWTON USERS-need you
Federico Richiusa
on Jul 23, 2019 at 11:26:09 am
Hi all.
Is my first time with Newton 2, so might be that is an easy problem to solve.
I create my animation (is basically a bunch of rectangles over a table).
Set a plane for the table and one for the floor, and two spheres which hit the rectangles because i need this kind of explosion effect.
Everything is fine, the preview works good and then i hit render.
It renders and then in the new comp which is created, my rectangles has a different initial position.
What should I do?
