When is a good moment to render a comp to add effects to it and proceed to the last render?
Felipe Prado
on Jul 17, 2019 at 10:22:12 pm
When is a good moment to render a comp to add effects to it?
To give you an example, let's say I make a comp, and inside that comp I have this really big animation, it contains a lot of layer and all of them are white, because later I will add color to it, will add other effects and stuff, my question is, when should you jump to that stage, to colorize it and add other effects, also considering I will be using 3D and camera on it!
Let me know thanks in advance!
Walter Soyka
Re: When is a good moment to render a comp to add effects to it and proceed to the last render?
on Jul 18, 2019 at 2:37:47 am
You can pre-render [link] or proxy [link] any time you want, but I would recommend leaving everything in your comp live all the time.
Pre-rendering means that change management becomes more difficult; some changes could require you to go back to the beginning, make a set of changes, render, import, and then make additional changes on top of the new render.
If you need to work a little faster, here are some performance tips (especially the last three sections):
https://helpx.adobe.com/after-effects/using/improve-performance.html
Walter Soyka
