rendering lumetri before a noise pass
Mark Foerster
on Jul 14, 2019 at 6:08:15 pm
Hello All, I have a lot of noise reduction to do (neat) and when combined with lumetri it really slows the timeline down. I'd like to prerender the lumetri adjustments - and then apply noise reduction - yet keeping all the clips available on the timeline for timing tweaks and the like..My usual Gorilla technique is to output the video layer and roundtrip it back in - that makes everything spring fresh again, but in this case I'd like the 200 or so clips available for adjustments..
Thanking you in advance
Mark Foerster
Toronto
Walter Soyka
Re: rendering lumetri before a noise pass
on Jul 18, 2019 at 2:50:32 am
I'd suggest doing the noise reduction first, then coloring afterwards -- you should get better NR results, better keying/secondaries when coloring, and I'd think you'd be more likely to want to tweak color after the fact than you would want to tweak noise reduction.
Walter Soyka
Mark Foerster
on Jul 18, 2019 at 3:10:27 am
Thanks Walter!
