Shape position relative to end of line layer
Markus Stone
on Jul 11, 2019 at 6:29:13 am
Hey all,
I'm trying to make a template for a lower third graphic.
The below graphic animates on nicely. Text goes over the center bar.
All good.
But the length of text will change (people will have different names), so I want the two circles on either end to maintain a fixed position relative to the ends of the line.
My understanding is that expressions can't access XY co-ordinates of shape vertices (only scripts can).
Anyone have any ideas?
Cheers
Markus
Markus Stone
Re: Shape position relative to end of line layer
on Jul 11, 2019 at 7:32:45 am
Here is a video of the desired effect.
I can achieve the desired effect - just hoping to standardise the interface so I don't have to move the smaller circles by eye everytime there's a new name
Cheers
Markus
Walter Soyka
on Jul 11, 2019 at 1:06:19 pm
[Markus Stone] "My understanding is that expressions can't access XY co-ordinates of shape vertices (only scripts can)."
Actually, there's a new feature that will help you. Expressions got access to path points in Ae CC 2017 (v15).
See the reference here for more:
https://helpx.adobe.com/after-effects/using/expression-language-reference.h...
Walter Soyka
Markus Stone
on Jul 14, 2019 at 12:25:11 pm
It looks like the very thing I need, only I can't get it to work because I'm still so new to the magic of expressions.
This is what I have. I've played with a bunch of permutations too;
thisComp.layer("Shape Layer 1").content("Rectangle 1").content("Rectangle Path 1").position.points(1);
I keep getting the error that (the above line) "is not a function".
I assume that means my syntax sux, but I don't know what to change here.
I would be very greatful for a little nudge in the right direction.
Cheers
Markus
